As promised, Salesrep sent me a number of tubes of Schaeffers Moly 221 Ultra grease. Unfortunately it arrived just as I had completed excavation on the job I was on. I finished that today and will start another tomorrow, so I'll give further details after that.
What I can tell you so far is that this grease is very tacky and sticky! I dabbed my finger in it to look it over and couldn't get my finger clean! No matter how many times I wiped, there still was residue on my fingers. The only way I could clean it was with solvent. If it sticks to the bushings this well, it should be quite a feat!
I did grease my machine after digging to see how it went on, then it rained that evening. The Schaeffers grease did not change color as my other greases have from the water. It says on the tube it is water proof, I'm thinking this is the proof.
I'll report back after some more use. I'll probably keep my same grease schedule for safety's sake, but I'm betting I use less grease than in the past based on what I've seen so far. Stay tuned.....
