S330 Fluid Leak
Tracyiver1
Franklin, TN
I have an older S330. About 400 hours.
It’s started slowly dripping fluid from the 3 bolts in a row on the underbelly approximately centered between the rear wheels.
Any ideas what it might be and what it’ll take to fix it?
Thank you.
crewchief888
NWI
you cant access anything from underneath. the plate you are seeing is a cover for the fuel tank drain and possibly a chaincase drain.
only way to find whats leaking is to lift the cab.
