Runaway 6-71 Detroit
GregsHD
Mahood Falls, BC
Self Employed HD Mechanic
Okay, I got confused after I reread the first post. You mentioned air throttle, and electric shut down solenoid.
RZucker
Wherever I end up
Mechanic/welder
With the shut down cylinder extended you wont be able to move the rack tube. it will be a good time to check the racks, a stuck control rack will be in toward the injector body. the rest will be pulled out. The racks are the little rods connected to the levers on the tube that go into the injectors.
kshansen
Central New York, USA
Not sure if this will help explain things but I'll give it a try!Detroit Rack.png
In the picture above the tube with the green arrow is pointing along with the levers with the two slotted screws in them is what people are suggesting you rotate. I know your's is a little different as yours has screws with jamb nuts and springs holding them in position against the screws. Your style should not tend to go to a run-away condition but I won't say it is not possible.
What you need to check on the injectors is the movement of the yokes the red arrow is pointing towards. You should see them all move in and out the same amount on every injector. You may have to turn on the key to get the shut down system to allow the tube to rotate free.
If one or more of the yokes(red arrow) does not move in and out that would be the problem injector.
Anyone want to add or clarify what I'm saying here feel free as trying to put things in to words instead of being there and showing it in person can be tricky!
Looking again at the pictures of this truck I'm thinking the air solinoid is powered to kill engine so might be easy to just remove the hose from it to let you move the rack tube by hand with a little help from a pair of pliers!
kshansen
As a side note on this problem I have a question. Did Detroit do away with the emergency shut down flapper when they went to the spring loaded levers on the tube with the single screw adjusters for the rack? 99.9% of the Detroits I worked on over the years had the two screw adjusted rack levers and I just don't recall how the one or two I may have worked on with the spring loaded levers like this truck has.
RZucker
Wherever I end up
Mechanic/welder
Yes they did, I have had a stuck injector in a 12V71 with spring loaded rack levers and it was still tough to get it shut down. Of course the stuck injector was at full fuel and part of a complete "white box" set. This was 300 feet out the shop door after an inframe.
kshansen
So I guess if one injector is able to keep a 12V-71 running against the spring loaded lever I can imagine that it could even be worse for a litte 6-71!
Maybe not going to the ballistic state like the rigid levers but enough to cause one to not want to stay put and do what needs to be done.
Seems like I recall hearing someone say the best way to stop a run-away was to point a CO2 fire extinguisher at the air filter. Not sure if that would be a good idea if running without any air intake filter.
td25c
indiana
Shut off the air supply and it will calm any runaway down real fast .
Ask Robbie Lawler ? " Funky Ben Askren " shut off the air …..
Birken Vogt
Charter Member
Grass Valley, Ca
It would probably work for a minute but what if you ran out of CO2 before the engine completely stopped? It would pop right back to 4000 RPM and you would be standing there with an empty extinguisher in your hand.
PonderosaPete
Stillwater, New York
New twist to the story. It finally stopped raining and I was able to put vice grips on the tube and with the solenoid disabled everything works back and forth and super smooth. The new twist is, the fellow who comes and helps???? Me out once in a while changed the oil one day when I was working on the brakes. Evidently the truck has the wrong dipstick in it. Instead of adding 7 gallons of oil, which I believe is the capacity of this engine, he kept adding oil until it said full on the stick which was 10 gallons. So I figure 3 gallons overfilled. Then it sat for 2 weeks with the extra 3 gallons. Could it have sucked oil out of the crankcase immediately when I started it and went into runaway? I’ve since drained 3 gallons of oil out but could residual oil still be in there somewhere? Thanks again for all your help!
Vetech63
Oklahoma
You shouldn't be able to overfill the engine to the capacity that it overfills in the airbox providing your drains on the side are clear. Yes it can get there but the drains are there to keep oil build up from happening. These engines can run away from engine oil, especially when the oil is saturated with diesel fuel. Most of the time I have seen it is from dirty engine oil and a turbo/blower seal failure or plugged up airbox drains. You would more than likely have a hydraulic lock on a cylinder if the air box was THAT full of oil. Stranger things have happened but I don't feel at this point you have found the issue 100%.
When you operating the fuel control tube, did you actually watch each injector control rod move in and out of each injector? The control rod will still move with a stuck injector since they are spring loaded. An easier way to tell for sure is to remove the control rod pin from the rack itself (it is a small dowel pin with a cotter pin keeper). With the control rod disconnected, the injector rack should move from fuel to no fuel (in and out) with NO tension at all. If there is any drag then you will need to locate which injector is causing it. If your are good at that point, come back and post and we can give you other things to look for, but the faulty injector movement is the most common cause of a runaway engine.
kshansen
You shouldn't be able to overfill the engine to the capacity that it overfills in the airbox providing your drains on the side are clear. (snip).
I'll second everything Vetech63 said!
I'd have to do some digging but seems there is a chart that will give oil pan capacities for various oil pans, or maybe I'm thinking about an 855 Cummins manual????
I do like the idea of pulling the pin on the fuel tube and seeing how it works with the governor out of the picture. To make it clear see picture below. The yellow arrow is pointing to the pin Vetech63 is taking about. One thing if pulling that pin I would suggest putting some paper towel under that area as the oil drain back hole is right near there!
One more suggestion is when removing the cotter pin take out the one that is to the right in the picture and reinstall it from the left side as you look at the pin in picture.
Really doesn't matter BUT! if you get interrupted and forget to put the new cotter pin in there is a good chance the pin will stay in place as the valve cover will tend to prevent it from falling out. You really don't want to have that pin come out while engine is running. You could end up with all six injectors going to full fuel and the shut down solenoid will have no way to stop it!
One more suggestion. If at anytime the engine does try to run away again and you decide there is nothing you can do and you want to make a run for it, run in a line parallel with the crankshaft. If parts are going to fly out they will most likely come out the side of the engine!
old-iron-habit
Moose Lake, MN
Before I started it again I would have a emergency system in place to shut the air off to the engine. A piece of board or plywood to stick over the intake with the filter removed. A heard of a sleeping bag sacrificed by wrapping over a air cleaner intake in the past. He was a bold fellow. Whatever you can easily use to stop the air from entering the engine will only help you in a runaway.
mitch504
Andrews SC
My brother rebuilt an 8v71, and when he started it, it ran away. He had put a piece of 1/4 plate by the front tire, but somebody took it without him noticing. He ran around the shop hunting something, and grabbed a piece of 1/4" plywood. He put that over the intake and she sucked a perfect round hole in it and kept on screaming til she grenaded!
RZucker
Wherever I end up
Mechanic/welder
I heard a story about a guy that threw the service manual over the blower on an 8V-71 and it ate the book a page at a time and blew confetti out the stacks.
OL2STROKER
Broadalbin NY
Easy fix i tried to convey over the phone but i think OP was a little apprehensive about tackling it anymore. After i reinstalled the throttle return spring the problem was solved. It wasn't running away just immediately going to governed rpm. Fun fact these detroits dont have an internal throttle return so if you remove it from the governor lever it will not return to idle by itself any more. Also attempted to adjust his clutch for him and did get it a little better but i think it needs a clutch. OP would like to have me back at some point to give her a full tune up and I'm happy to oblige. OP is a real good old school guy great to work with. Happy to report a happy ending here, but i told em if he keeps this thing painted junk cummins tan it's going to keep trying to kill itself. Lol
kshansen
Looks like the wiring could do some with a few zip-ties! And about the hose going to whatever it is under that cookie can?
ScottP
Jayess, MS
Shop Forman/Lead Technician/Truck Driver
LMAO!!!!!!!!!!!! THESE POST KEEP ON HELPING NO MATTER HOW OLD THEY GET MY FRIEND , I NEEDED THAT LOL IN A SURE NUF 'STRETCHED WIRE HARNESS WEDNESDAY' KINDA WAY..MANY THANKS!
