Hendrik
You did read through the roadranger publications? http://www.roadranger.com/ecm/group...roadranger/documents/content/rr_trsm-0515.pdfI followed the air lines from my stick today and unbolted what I thought was the cylinder as discussed above. In hindsight I'm not sure that it was.
I reread mitch's post and went looking for the filter. couldn't undo that because I don't own a spanner large enough, went to buy one, couldn't find one in several shops but did get a jumbo spanner set ordered in. hopefully that will arrive tomorrow and I'll have another crack at it...
The system works on a relay principle, rather than having big airlines and a huge range shifter in the cab, they run small air lines into the cab, these air lines go to a slave valve (which is like a relay) on the side of the box, from this slave valve big air lines go to the range cylinder on the back of the box, page 4 has a nice picture. Note there is an air filter which could be partially blocked.
For the 13 speed this is the manual http://www.roadranger.com/ecm/group...roadranger/documents/content/rr_trsm-0430.pdf
