RGN down for the count
Discussion in 'Trailers' started by Shimmy1, Sep 8, 2015.
  1. Shimmy1
    Shimmy1 Senior Member
    Aug 14, 2014
    3,091
    North Dakota
    When to unload my hoe today, noticed one side of the trailer was sagging down. Discovered the big hinge pin in the neck was broken nearly clean off on one side. Got this far today. 4" diameter pin, the pin bosses are about 6" long, pin is NOT MOVABLE. I don't have a piercing torch so a friend is going to come with an air arc and blow through. I went through almost two tanks of air cutting and heating, trying to get them out myself.
  2. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Luckily you caught it when you did .
    Any other damage ?
    Might be a good idea to replace both pins .
  3. Oxbow
    Oxbow Senior Member
    Nov 22, 2012
    859
    Idaho
    Dang Shimmy, not good, but as TD said at least you caught it when you did!
    We had one of the dogs that allows deck height adjustment crack at the weld and that made me panic.
  4. Shimmy1
    Aug 14, 2014
    3,091
    North Dakota
    It's one pin, all the way through. So, there are 3 bosses underneath that have a chunck of pin stuck in them. The pin is 66" long.
  5. Shimmy1
    Aug 14, 2014
    3,091
    North Dakota
    Won't know for sure until we get the new pin and try and install it. The side that broke looks like it might be tweaked a little, but those frame sides can move in and out when they're not held by the pin so......we will see.
  6. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Yeah got it Shimmy 1 .
    Just trying to figure out why the shaft broke .
    Any grease fittings on the pin boss ?
  7. Shimmy1
    Aug 14, 2014
    3,091
    North Dakota
    There was a fitting on each end of the pin. They have never taken grease. Tried to get them open with one of those grease busters, but never succeeded. I've only had the trailer for a couple years. It is a '95. Wouldn't think you could twist off a 4" pin but apparently it's possible.
  8. Nige
    Nige Senior Member
    18,403
    Was there a piece of the pin that came out from the outside that you didn't torch..? A close-up photo of the broken end would be interesting......
  9. Shimmy1
    Aug 14, 2014
    3,091
    North Dakota
    Haven't got it out yet. It is siezed in the outside as well on the side that broke. It wasn't broke completely off yet, luckily for me. I'll try and describe it though. It was very rusty, for sure it has been broke a while, but still hanging by a thread. It was like a bomb went off in the center of the pin. All kinds of square-ish shards, almost resembling keystock. There were many fractures parallel to the pin, and then the pieces just failed one by one.
    Now that I'm describing it, I'll bet it was caused by the pin seizing in the pin boss, and many twists back and forth. Grease fitting are put in things for a reason.
  10. Shimmy1
    Aug 14, 2014
    3,091
    North Dakota
    What it looked like before I cut it apart.
  11. Nige
    Nige Senior Member
    18,403
    Hard to say from that angle. If you can preserve at least part of the pin without having to cut it where it failed the fracture face might be interesting to look at.
  12. lantraxco
    lantraxco Senior Member
    Jan 1, 2009
    7,695
    Elsewhen
    It is hard to tell, but looks to me like a torque failure, not what you would expect if it just sheared?
  13. Nige
    Nige Senior Member
    18,403
    I agree with Shimmy though - maybe a lack of grease had something to do with it...... those grease nipples weren't put on as ornaments.
    Also maybe the pin is designed to rotate somewhat under load..?
  14. JBlackwell
    JBlackwell Well-Known Member
    Jun 1, 2009
    100
    Daingerfield, Texas
    Is that an XL Specialized trailer?
  15. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    That's why she broke Shimmy1 . :yup
    Have seen scissor hoist on dump trucks fail in the same way . Pins & bosses tight & lack of grease , something has to give .
    I was going to suggest installing grease fittings in the neck boss .
    Can you get a new shaft from the dealer ?
    Smack on the old one with hammer & center punch to see how hard it is . I bet it's just a 4" diameter piece of cold roll shaft ?
  16. Shimmy1
    Aug 14, 2014
    3,091
    North Dakota
    Yes.
  17. grandpa
    grandpa Senior Member
    Oct 16, 2009
    1,872
    northern minnesota
    Well Shimmy,,, that's too bad. That's one of the results of living in cold country when they salt the roads all the time. I bought an end dump that had the frame bent because the hinge pins seized up. Best advice would be to throw your truck keys in a pale of water at night. When the day comes they become froze in, leave the truck and trailer set there til spring when you can reach in and take the keys out of the water. (wish I could practice what I preach.)
  18. Shimmy1
    Aug 14, 2014
    3,091
    North Dakota
    Yeah, in three weeks. It took XL 8 hrs. to get a blueprint to the dealer so we knew for sure what size it should be. 3 15/16". What an oddball. So, my machine shop is building one. Whatever they're using it comes oversize and they will turn it down to proper size. Drill the bolt holes in the ends for the lock collars. $850. Thought that is pretty reasonable. It's 64" long. And yes, I will be installing grease fittings in the pin bosses.
  19. Shimmy1
    Aug 14, 2014
    3,091
    North Dakota
    Yeah, the trailer is 20 yrs old. I would be nice if guys knew what the hell a grease gun is for. I tried to get the pin to take grease when we got it. Wasn't happening. Never thought it would come to this though.
  20. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Sounds like a good plan Shimmy1 .
