willie59
Glad to hear you got is sorted out sid rust.
I have an update for the thread. Changed the control valve seals on a 753C recently, they're a kind of a PITA compared to the 763G and 773G. Because of the mounting location of the control valve, doesn't do any good to remove the machine side cover, it won't give you access to the control valve, everything has to be done from the topside. And the front of the control valve is a Bi-itch to get to because the loader arm manual descent valve body is in the way. Aside from this, the repair is pretty much the same method as other models, we'll just cover a few differences doing the 753C.
First, like with other models, remove the bucket, raise loader arms, install safety prop, and tilt bucket coupler all the way forward (dump). Make certain you have cleaned the dirt and crap in the belly of the machine under the control valve, you're going to need that hole open in the belly of the machine to drain oil into a pan when you pull control valve spools out.
The 753C had the hyd tank behind operators seat, you're going to have to drain the tank or you'll lose your oil when replacing control valve seals.
Best way to drain this tank? LoL, you guessed it, the suck bucket. Ha ha ha ha
Here's one of the problems you're going to have on this model, getting to the allen head screws that hold the dust boots and seal retainers on the front of the valve body, you can't get your hands in there for all the stuff in the way.
Now, removing the control valve to perform repairs would be a major disconnect deal, yuk! Likewise, removing that valve body for loader arm descent wouldn't be a piece of cake, no real good options here. Here's about the best you can get to access the front valve components.
Disconnect and remove this crossover pipe.
Remove the hose connected to the T fitting.
