Tinkerer
One of the hydraulic facilities that I buy hoses at, measures the finished crimp with a micrometer.
If you have installed and it's not leaking, I wouldn't worry about it. Might go 20 years that way.So im gonna go back to napa and have them re make this hose
We have a gates hose maker where I work, every size hose has a specific squish pressure that involves a die that makes the crimp inside an outer cone and the extra material inside the fitting will interfere with the crimp on the crucial part of the fitting,the barb...I have made hundreds of hoses and would not trust the one they gave you....That sure looks like a Gates crimp to me...
If the die can't get a good squish due to all the extra foreign material in the fitting, it just may be an issue, especially for the poor sucker standing next to the hoe when it pops... just sayin...I wouldn't hesitate to use them there's inserts the hose is squeezed against and the thickness of the shielding would be insignificant.
Different application man, probably the setup Nige was referring to..Maybe uses a different type of fitting and different sleeve, but those in the photo don't look legit to me...I have a firewood processor that has a bunch of hoses on it, and every hose has the fabric protective cover crimped under the fitting. Came from the factory that way. Haven’t had a problem yet...
I'm ask my weatherhead hose rep if I can crimp spiral wrap under the fittings and see if I can freak him out next time I see him
Exactly.The ribs and the grip is on the inside of the hose right? I think you'll be alright.
