The other day I asked for suggestions about repairing a badly bent line and the responses were informative and mixed.
Since then, I've found another Eaton/Weatherhead product that is a hose end/ ¾ ferrule.
So I have lots of choices:
Weld on a fitting.
Braze on a fitting
Silver solder that fitting.
Use the ferrule fitting.
What is the difference between braze and silver solder from strength and vibration perspective ?
A Master plumber said vibration was a bad idea with ferrule type fittings. What do you think ?
I'm avoiding welding because I'm not very good at it and there is only a generator where the machine is.
Thanks for sharing your experiences and opinions.
Weld on a fitting.
Braze on a fitting
