mike_legere
Reclamite® Rejuvenating Emulsion
Often used as a construction seal for brand new asphalt surfaces in order to seal in-depth to prevent asphalt stripping and other water induced damage from day one. The application results in tight waterproof asphalt, better compaction, stronger cold joints, sealed segregated areas, as well as improved flexibility. Cracking is postponed, asphalt becomes more resilient and lasts longer especially with additional maintenance seals every 5-7 years. We can prove the cost effectiveness of this type of program.
Reclamite® can also be used as a maintenance seal on older oxidized and ravelling cracked pavements as a means to cost effectively lengthen the service life.
www.superiorroadproducts.com
