I'm not ignorant to hydraulics, or at least understanding the engineering side of hydraulic power, but I am trying to repair a genie boom lift that is just pissing me off. Mostly because the schematics really suck, and I don't know what types of valves I am looking at just by looking.
I have SEVERAL problems, and I am about to set this POS on fire and walk away, but as a starter, this is an articulating boom lift that has sat for probably 10yrs I would guess. Original owners screwed it all up with wiring hacks, then a friend bought it and it sat some more. Now I am in there. God how I hate fixing other's work.
So first issue, boom raise and hold. When the boom section is commanded to go up, it fires a solenoid in the main hydro block and sends fluid to the piston side of cylinder. the cylinder has what I believe is counter balance valve or other "load check" device, with an emergency lowering handle, and a solenoid right on it. I have determined that lowering is all done at that point, as the rod end goes through this valve and the schematic shows the rod end otherwise to just return to tank.
2 issues.
1. When commanding boom up, engine labors hard like its doing something, I am just bumping the toggle. Eventually the boom will start to lift and the engine hardly labors. So I would consider the initial efforts to be dead heading for some reason. I suspect the valve on the cylinder.
2. Once boom is lifting, I can raise it fine, but as soon as I stop lifting, it will lower like I am holding the lower toggle. It's not like a little bleed down, that sucker is coming down!! I further opened the emergency lowering valve once and it lowered a touch faster, but not much.
The way I see this, everything is controlled in that valve, but I have NEVER seen one of these fail!? The fluid is healthy looking. It does not appear water has invaded this machine. Where I am at is either that valve has some sort of issue, or the piston seal is simply beyond toast! ??? BUT, like, should that valve not be able to account for that? Now, I do realize there is some lost math with the theories about fixed displacement in a cylinder, but if the piston is not sealing, the rod ends up acting, which increases pressures, possible beyond relief.
But this is fully sucked in, no people in basket, etc. I am just puzzled. I cycled cylinder a few times to try to get some heat from it, and nothing!
I will just go ahead and drop question 2 in, as it might relate. The basket "level" function does not work, but same deal here, when I activate either switch, up or down, the basket does not move at all, but the engine tells me something big is trying to happen. And I now have a head seal leak on what I believe is the "master" cylinder for leveling. If not familiar, when the boom goes up, the boom forces the aft cylinder to stroke, which is coupled to another cylinder under the basket so one cylinder forces the other to move just by stroking.
However, the cylinder under the basket does have a pair of valves on it, as I would expect, so if something happens, that basket cannot just dump humans on da flow. It almost seems like those valves too are having issues. Or I am missing something. When I boom up, It certainly moves that slave cylinder, and I can see it stroke, but I see zero movement at the basket. This is why I think the slave cylinder is now leaking. It just got some serious fluid pressure for some reason.
2 issues.
