Robertogatos
Hello, first time post, but long time reader.
This is my first large excavator, plan is to use it primarily as a carrier for a 48'' Pro-Mac mulching head to knock back brush on our ranch. Other functions will be some occasional digging, and lifting / material handling while we're without a crane. The machine has some nice features like the DigMor (extend-a-hoe), Wrist-O-twist (bucket swivel), Cab heater / AC, rear axle locker, and 4 corner stabilizers. The machine is as close to a new as you can get, and everything is in excellent condition / appearance, minus the paint job that became a bit faded a bit under the desert sun. Best part is the machine only has gathered 200 hours!
It was in non running condition when we took delivery, and after going through all the fluids/filters, new tires, she's up and moving around. I already spent a few days switching the controls over to a conventional S.A.E. / Cat pattern, which makes the machine actually workable. The Case pattern was a joke, but after switching over, I'm right at home.
Now that the carriers up and moving I'm working on getting the work tools setup, and quirks of the tractor sorted. This is where I could use some help...
I'm trying to find a bucket that fits this machine, but i'm not having the best of luck... Is there a class of bucket I should be looking for? Something used would be preferable to save some money. I'd assume the machine would use the same bucket mounted directly to the stick / linkage as it would the Wrist-O-Twist attachment... The pins mounting the wrist-o-twist to the stick / linkage are all just under 2'' diameter. Something like 1.985''. The odd thing is that the pin diameters for the wrist-o-twist / quick coupler are larger than that, at roughly 2 1/16''. The Wrist-O-Twist / quick coupler clamps down on one of the pins (furthest from the machine) but not the one closest. Seems the bucket would have a ton of clatter If I were to use the 1.985'' pins that would mount the bucket directly to the stick. Is this big of a tolerance necessary for the quick coupler to be effective? Whats the best thing to do here? Am capable of machining / fabricating pins / mounts but I'd like to build something that would fit other machines in the future, and conform to a convention. Do any machines still use this pin diameter / width / spacing? The pins are 14'' on center, stick opening width is 11 15/16'' and bucket ram linkage width is 7 5/16''.
What would be a good size bucket for this machine? It weighs 40k and am mostly digging in fractured sand stone. For reference, our 580 super l swings a 24'' bucket nicely through just about everything around here. I'd also like to get a bucket to use for loading piles of gravel into trucks. What would be the biggest I could go on this, only moving bulk fluffy materials to quickly load trucks?
Is there also a resource to look at what service bulletins were released regarding this machine? I know there were some, but case dealers haven't been very much help on any of these points.
Thanks for any of you input, I'm looking forward to getting some time on this machine!
