Pulls slight right going fwd, dead straight when backing up
mudnducs
Jonesborough, Tennessee
retired mech eng
Hi Gents....I'm not alarmed by the problem. Bobcat 442. Pulls slightly right when driving toward the blade (fwd) (maybe 2 ft to the right in 100' of travel) but goes dead straight when "backing up".
Anything I should be watching for?
willie59
Knoxville TN
Service Manager
Check the pilot valves that the pedal/levers operate for dirt, it only takes a little bit of dirt/debris to prevent moving the pilot valve spool fully when you operate pedal/lever, and just 1/16" of movement of those spools makes a big difference.
John C.
I think that machine has manual travel controls. I believe there are stops on the levers or maybe a piece of linkage is bent. If I remember right you can remove a plate in the floor boards to check it.
