Great point kshansen ! Feller has to be careful about flying metal .
What I like about a race punch & big old hammer is it fits most of the bearings we have .....
Few cases where the bearing race is in a blind hole like on a dozer final drive . Those get cut in half with a torch .
Ran in to a little trouble last Friday evening installing new front wheel bearings in the 68 Ford Galaxie 500 .
They did not leave much of a lip on the backside to get a hold of . Race driver kept slipping off the 1/16 inch edge of the bearing cup .... OK ..... I'm a hard headed SOB as well
Went back to the tool box & found a 3/4 drive socket that fit the bearing cone perfect & would drive though the hub .
Well now ..... That bearing cup gave up & fell rite out after a few smacks .
Looks like there is plenty of bearing cup showing to get hold of . We would just start pounding with the race driver .
No give .... weld a bead around & letter cool of ....
Still no give hack in two pieces with a torch .
Prep the clean up the bore with a die grinder & install the new bearing race .
