Porpoising
Willie B
Mount Tabor VT
Electrician
It is the typical modern winter in Vermont, nothing extraordinary, snows a bit, then it melts. The ground has only frozen shallow, then it thaws. Friday we got rain changing to snow late in the day. By Saturday morning, 7" of snow.
It didn't need doing, but giving the Dresser TD7G (7 tons) a bit of exercise seemed like a good idea. I plowed the road to the "land". Other times I've done it I've had better luck. This was dry snow mostly, with a thin layer of wet sticky stuff at ground level. It was plain miserable to plow! I couldn't adjust the height of the blade fast enough to make a flat layer of snow without making moguls! Tried raising the blade a few inches, leaving it steady, that made it worse. Tracks seemed to ride up on something, then tip forward as it came down. I couldn't raise the blade fast enough to avoid digging into the gravel. Nothing seemed to work well. Am I doing something wrong, or is this an impossible thing I'm trying to do?
DB2
Winnipeg MB Canada
Float ? No porpoise puns intended
Tongue firmly in cheek
How about back blading ? No need to rotate the mold board 180 degrees either.
Ronsii
Western Washington
s/e Heavy equipment operator
I can't remember if your blade angles or not.... or were you trying with it angled?
Willie B
Mount Tabor VT
Electrician
Road is soft with all the freeze thaw cycles. It's made of crushed stone, so it drains well, but the freeze thaw cycles leave it pretty loose. Dozer blade just digs in. Running backward was about the only thing that did work. Doing that, it floated OK.
It occurs to me the cutting edge on a dozer blade lays down to slice a layer of dirt. A snowplow blade is steeper where it hits the ground. Every snow plow I've had I use shoes, but I doubt they'd be enough for a heavy blade like this. I wonder if a piece of pipe 8' wide cutPlow.jpg open to fit over the edge would allow me to float the blade?
Tinkerer
Is there an adjustable arm on either side of the blade ?
If there is, screw it out to change the pitch of the blade.
I never had to do that for snow plowing, but when finish grading hard dirt it makes a huge difference to stop the blade from diving in like you are having problems with.
Willie B
Mount Tabor VT
Electrician
No provision to change the angle on this one. PAT I believe it's called.
cuttin edge
NB Canada
Finish grader operator
I'm no tractor man, but I can spread lose material without the need to back drag. I can also carry a grade. With a large machine, I can Handel a strait blade, but I can't run say a D4 unless the blade is angled. I have never been able to cut hard material without the moguls as you say. I think I'm doing good, then when I back up..... Kaplunk, Kaplunk, Kaplunk, spills coffee.
Hobbytime
usa
talk about killing a fly with a sledge hammer..LOL...the dozer blade is just TOOOOOO heavy for that..I have used my D-58 for moving large frozen solid piles of snow into the field when I run out of room from pushing snow with a tractor and bucket on frozen solid ground...otherwise I have some BIG divets to replace...I think even an 8 inch pipe with slot to slide over bottom of the blade will still dig in if its that soft or just go over the top and not move anything, but its worth a try...only other idea is some type of wheel mechanism to put on front blade to keep it off the ground, as large tires wouldnt get pushed into the ground like shoes could...
my roto tiller has steel wheels in the back to keep it at a set height...
Willie B
Mount Tabor VT
Electrician
I thought it looked easy seeing it done. I'm getting to where I can spread processed material. This was an exaggerated version of what happens first time cutting small sapling stumps out of overgrown pasture. I'm not clear what it was riding up on, I think the wet snow at bottom was lifting off the road stuck to the tracks intermittently It'd climb something under the tracks like climbing over a tree trunk (small) then pitch down the other side. Like a boat on waves. Correcting the blade to compensate was near impossible.
I'm thinking of adding shoes to the blade to see if it helps. I've considered a real snowplow, did it once on a backhoe, it was ungainly, and any blade angle at all it pushed the tractor sideways.
Willie B
Mount Tabor VT
Electrician
That's all I had there. It wasn't likely necessary to plow at all. Probably be melted by Tuesday. I wanted to charge the battery & exercise the old girl. I'd have thought the crawler would be functional for this. When the ground freezes it works great!
Not that good a operator myself where would need guide wheels or shoes to keep from ending up with a Motocross jump track. Can eventually smooth out road cuts and grade outs but a well worn machine weak hydraulics that tend to drift, slowing reflexes and a bad set of peepers makes a LONG Day!! That using either my old farm tractor and drag blade or bucket or the track loader(mine is a full 12 T)
check
in the mail
Every time I try to plow snow when the ground is not frozen, I screw it up regardless which machine I'm using. I find it's best to just drive over it until the ground freezes good, then plow. The downside is there is always going to be an inch or so of packed snow/ice on my dirt driveway, I just have to live with it.
Pixie
NH
remodeling
How about hanging a 'ski' of some kind over the blade on a chain..... About 2 feet long and in line with travel ?
Though I don't have a dozer, I have a short tracked unit with blade that does the same thing. ( Bombardier J5 ) I also have a crushed stone driveway and just pack it till ice forms on the ground and I can use my snowcat.
petepilot
central shenandoah valley va,
plowing snow with a dozer is the exact opposite of spreading gravel with a dump truck you can`t set the blade first you have to be moving then lower the blade gradually until you get to the ground. pop the tailgate then take off with a load of gravel and you`ve left a hump :D
:p
Willie B
Mount Tabor VT
Electrician
Willie; Is there any chance one of the hydraulic cylinders has a piston leaking badly ?? That would explain the quick drop problem.
2016 we went through it. Underbelly pins replaced, bushings not replaceable but not bad. Everything else on the blade and C frame got new bushings & pins. The tilt surfaces got replaced, shims done, the blade is probably tighter than new. All works as spec, including bigger pins & bores throughout the valve linkage. Blade works perfectly.
Now one might argue my anticipating a needed maneuver soon enough could be improved, but yesterday it was riding up on something, then tipping as it passed over center. The hydraulics were just not fast enough to lift the blade before it dug.
