Porpoising
Discussion in 'Dozers' started by Willie B, Feb 9, 2020.
  1. Willie B
    Willie B Senior Member
    Jan 3, 2016
    1,277
    Electrician
    Mount Tabor VT
    It is the typical modern winter in Vermont, nothing extraordinary, snows a bit, then it melts. The ground has only frozen shallow, then it thaws. Friday we got rain changing to snow late in the day. By Saturday morning, 7" of snow.
    It didn't need doing, but giving the Dresser TD7G (7 tons) a bit of exercise seemed like a good idea. I plowed the road to the "land". Other times I've done it I've had better luck. This was dry snow mostly, with a thin layer of wet sticky stuff at ground level. It was plain miserable to plow! I couldn't adjust the height of the blade fast enough to make a flat layer of snow without making moguls! Tried raising the blade a few inches, leaving it steady, that made it worse. Tracks seemed to ride up on something, then tip forward as it came down. I couldn't raise the blade fast enough to avoid digging into the gravel. Nothing seemed to work well. Am I doing something wrong, or is this an impossible thing I'm trying to do?
  2. DB2
    DB2 Senior Member
    Jan 4, 2015
    433
    Winnipeg MB Canada
    Float ? No porpoise puns intended
    Tongue firmly in cheek
    How about back blading ? No need to rotate the mold board 180 degrees either.
    DMiller likes this.
  3. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    3,160
    s/e Heavy equipment operator
    Western Washington
    I can't remember if your blade angles or not.... or were you trying with it angled?
  4. Willie B
    Jan 3, 2016
    1,277
    Electrician
    Mount Tabor VT
    Road is soft with all the freeze thaw cycles. It's made of crushed stone, so it drains well, but the freeze thaw cycles leave it pretty loose. Dozer blade just digs in. Running backward was about the only thing that did work. Doing that, it floated OK.
    It occurs to me the cutting edge on a dozer blade lays down to slice a layer of dirt. A snowplow blade is steeper where it hits the ground. Every snow plow I've had I use shoes, but I doubt they'd be enough for a heavy blade like this. I wonder if a piece of pipe 8' wide cut Plow.jpg open to fit over the edge would allow me to float the blade?
    John C. and DMiller like this.
  5. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    4,495
    On A Riverbank in IL. USA
    Is there an adjustable arm on either side of the blade ?
    If there is, screw it out to change the pitch of the blade.
    I never had to do that for snow plowing, but when finish grading hard dirt it makes a huge difference to stop the blade from diving in like you are having problems with.
    Ronsii likes this.
  6. Ronsii
    Jun 26, 2011
    3,160
    Western Washington
    DMiller and DB2 like this.
  7. Willie B
    Jan 3, 2016
    1,277
    Electrician
    Mount Tabor VT
    No provision to change the angle on this one. PAT I believe it's called.
    DMiller likes this.
  8. Willie B
    Jan 3, 2016
    1,277
    Electrician
    Mount Tabor VT
  9. cuttin edge
    cuttin edge Senior Member
    Nov 9, 2014
    1,002
    Finish grader operator
    NB Canada
    I'm no tractor man, but I can spread lose material without the need to back drag. I can also carry a grade. With a large machine, I can Handel a strait blade, but I can't run say a D4 unless the blade is angled. I have never been able to cut hard material without the moguls as you say. I think I'm doing good, then when I back up..... Kaplunk, Kaplunk, Kaplunk, spills coffee.
    DB2 and DMiller like this.
  10. Hobbytime
    Hobbytime Senior Member
    Sep 22, 2016
    695
    usa
    talk about killing a fly with a sledge hammer..LOL...the dozer blade is just TOOOOOO heavy for that..I have used my D-58 for moving large frozen solid piles of snow into the field when I run out of room from pushing snow with a tractor and bucket on frozen solid ground...otherwise I have some BIG divets to replace...I think even an 8 inch pipe with slot to slide over bottom of the blade will still dig in if its that soft or just go over the top and not move anything, but its worth a try...only other idea is some type of wheel mechanism to put on front blade to keep it off the ground, as large tires wouldnt get pushed into the ground like shoes could...
    my roto tiller has steel wheels in the back to keep it at a set height...
    DMiller likes this.
  11. Willie B
    Jan 3, 2016
    1,277
    Electrician
    Mount Tabor VT
    I thought it looked easy seeing it done. I'm getting to where I can spread processed material. This was an exaggerated version of what happens first time cutting small sapling stumps out of overgrown pasture. I'm not clear what it was riding up on, I think the wet snow at bottom was lifting off the road stuck to the tracks intermittently It'd climb something under the tracks like climbing over a tree trunk (small) then pitch down the other side. Like a boat on waves. Correcting the blade to compensate was near impossible.
    I'm thinking of adding shoes to the blade to see if it helps. I've considered a real snowplow, did it once on a backhoe, it was ungainly, and any blade angle at all it pushed the tractor sideways.
  12. Willie B
    Jan 3, 2016
    1,277
    Electrician
    Mount Tabor VT
    That's all I had there. It wasn't likely necessary to plow at all. Probably be melted by Tuesday. I wanted to charge the battery & exercise the old girl. I'd have thought the crawler would be functional for this. When the ground freezes it works great!
    DMiller likes this.
  13. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    2,080
    Oklahoma
    Willie is officially the Picasso of HEF!!!
    DMiller likes this.
  14. Willie B
    Jan 3, 2016
    1,277
    Electrician
    Mount Tabor VT
    Don't laugh! When I'm dead the value of my original art will skyrocket.
    DB2, DMiller, Ronsii and 1 other person like this.
  15. DMiller
    DMiller Senior Member
    Feb 22, 2010
    6,941
    Retired
    Not that good a operator myself where would need guide wheels or shoes to keep from ending up with a Motocross jump track. Can eventually smooth out road cuts and grade outs but a well worn machine weak hydraulics that tend to drift, slowing reflexes and a bad set of peepers makes a LONG Day!! That using either my old farm tractor and drag blade or bucket or the track loader(mine is a full 12 T)
    Ronsii likes this.
  16. Tinkerer
    May 21, 2009
    4,495
    Willie; Is there any chance one of the hydraulic cylinders has a piston leaking badly ?? That would explain the quick drop problem.
  17. check
    check Senior Member
    Apr 1, 2012
    775
    in the mail
    Every time I try to plow snow when the ground is not frozen, I screw it up regardless which machine I'm using. I find it's best to just drive over it until the ground freezes good, then plow. The downside is there is always going to be an inch or so of packed snow/ice on my dirt driveway, I just have to live with it.
    Pixie likes this.
  18. Pixie
    Pixie Well-Known Member
    Nov 12, 2011
    152
    killing trees, fixing stuff
    NH
    How about hanging a 'ski' of some kind over the blade on a chain..... About 2 feet long and in line with travel ?
    Though I don't have a dozer, I have a short tracked unit with blade that does the same thing. ( Bombardier J5 ) I also have a crushed stone driveway and just pack it till ice forms on the ground and I can use my snowcat.
  19. petepilot
    petepilot Senior Member
    Jul 7, 2018
    944
    central shenandoah valley va,
    plowing snow with a dozer is the exact opposite of spreading gravel with a dump truck you can`t set the blade first you have to be moving then lower the blade gradually until you get to the ground. pop the tailgate then take off with a load of gravel and you`ve left a hump :D
    :p
    DMiller and Ronsii like this.
  20. Willie B
    Jan 3, 2016
    1,277
    Electrician
    Mount Tabor VT
    2016 we went through it. Underbelly pins replaced, bushings not replaceable but not bad. Everything else on the blade and C frame got new bushings & pins. The tilt surfaces got replaced, shims done, the blade is probably tighter than new. All works as spec, including bigger pins & bores throughout the valve linkage. Blade works perfectly.
    Now one might argue my anticipating a needed maneuver soon enough could be improved, but yesterday it was riding up on something, then tipping as it passed over center. The hydraulics were just not fast enough to lift the blade before it dug.
    DMiller and Tinkerer like this.
