450/550 H's and J's are one of the most common machines in our shop. 1900 hours usually means you have wore though the bushings. By turning the pins and bushings on your machine, you would end up saving quite of bit of money. If you have broken bushings, I would run your tracks until you can't go any longer. At that point, you will either need new pins and bushings or new chains. You need to price check, get a couple quotes. Compare new chains vs. new pins and bushings. Check your rail height and make sure your link height is worth installing pins and bushings. Your local John Deere dealer or track shop can measure your link height. We probably average around 1000 hours after the turn depending on what material you are running in.
For all of you who don't think installing pins and bushings into smaller chains is worth it....
We installed dry p&b into D20 chains and saved our customer around $300 dollars. He picked his tracks up today and was tickled pink!
