Excellent. On the 143H control valve I struggled with recently even the local dealer service dept didn't have a plate - at least not according to them they didn't. All we got was a blank look when we asked about it, as much as what the f**k are you talking about.?
Strangely enough there was a plate available in the same dealer Parts Dept so the customer ended up buying that one. Go figure.
A bit more back story on that grader.
Two #7 clutch failures in short order. First one probably due to age (14k+ hours on the machine IIRC) , 2nd @ 60 hours after transmission rebuild.
Transmission was rebuilt by an independent mechanic, the control valve was sent to the dealer for refurb with all new springs & orifices, etc.
After installing the transmission the first time a dealer tech did "all the pressure checks" as part of the same Woirk Order for the control valve refurb but amazingly he never bothered to check/set the IPs, he just tested max pressure on all 8 clutches - and then he got that wrong as well. See below.
After 2nd failure the same independent tore down the transmission and found #7 clutch fried.
Digging into the control valve it was obvious it had all been rebuilt. Springs with paint on them, new orifices, etc.
The New style replaces a single spring with two springs (inner & outer) plus a spacer for additional preload. The new outer spring is a different P/N to the former spring.
However an inspection and measurement of the parts in #7 clutch station revealed that the dealer had rebuilt the valve as a mish-mash of Former & New styles. They had used the former P/N of large spring mated with the new P/N of inner spring and had also forgotten to install the spacer. As a result the max Pressure on #7 clutch was 90psi low when measured as per the new pressure specifications. What a clusterf**k.........
