PC200LC-8 AC issues/manul
southernman13
Florida,Ga,Tn
Retired
Just got it. Blows Cold. It will run few minutes then the fan cuts off. The compressor will still be turning but blower motor not working. It will come back on. The Freon levels are good. Any ideas. Or manuals to be shared. Thanks
southernman13
Florida,Ga,Tn
Retired
Looks like relay may be bad. We’re working on it now. It seems to be different than the rest of them in there
John C.
A lot of problems I have had with excavator AC were that the filters are plugged and the blow motor is also packed up with dirt and debris. I used to pull all the plastic out of behind the seat and take turns with a shop vac and an air nozzle to clear out the mess. The doors for the ducting need the same thing.
southernman13
Florida,Ga,Tn
Retired
He jumped out the relay and it was working but not up to par. The blow motor was coming and going. It would just stop and then would blow again. Not making any noise but could hear it pulsating. It is dirty. Going to take a shop vac and clean as much as possible this morning. We ordered a new new relay and blow motor. Hopefully this will cure it. .
