I have a 2012 komatsu 138 and it is having hydraulic issues. Machine has 4300 hours on it and have had this issue since 900 hours on it. The boom now and then come to a complete stop and as fast as you let off the lever and try again it would work. The dealer un hooked the relief valve on the bottom of the control valve and it made the boom stopping issue go away but the boom never moves at the same speed. It is a nightmare to grade with because the boom is never consistent It either puts too much pressure down while grading or it will pick up off the ground. Our local dealer and komatsu Canada doesn’t know what’s wrong they turned pressures down which just made the problem slower.The local dealer said it could be control valve but not confident it is the problem.hydraulic temperature has no effect on how the machine works. Any suggestions of what I can try to fix would be appreciated before I buy a 20000 part.
