PC 120-6
Dave Neubert
Monroe NC
Anyone know where you check the hyd. pressure I don't see a quick coupler on it need to check travel pressures
John C.
It's been so long since I've even seen a 120-6 but I seem to recall there will be a 17MM bolt head on the outlet port of the pump. It will be an O ring plug fitting that you can take out and put a quick coupler in.
John C.
As I recall travel pressure ran at 4,500 psi. Case was less than a pint.
