Oxy-propane rosebud torch
excavator
What do you put those on? I realize this seems like a silly question, but I've never been around anything other than a Victor or Smith torch body.
I have several of the large Harris tips that I threaded onto Victor wands so I can use with my Victor setup. If you want heat, they'll put it out.
We switched out our Acetylene for Propylene. Propylene is cheaper then Acetylene per bottle right now, but you also only use 1 bottle of Propylene to 4 or 5 bottles of Acetylene. We've cut up to 2 1/2" plate with the Propylene and its amazing, it leave a little bit of slag like a plasma would do on 1/2". We use to cut the thicker plates with Acetylene, it would do the job but is way slower and not as clean as a cut. And with the rosebud we have for the Propylene you can heat through 3" plate to red hot on the opposite side in about a minute. We just got different tips on our Victor torch and its working great. They say the Propylene will eventually eat up the Acetylene hose, but we'll worry about that later.
alco
I got one a couple years ago after the 955 bucket ripped open on one end. Haven't used it since.
Don't use regular Oxy hoses with propane I bought another set, forget what type it is, HEF told me what I should use
For propane, you need to go to type T hose. The standard type R will work....for a while.
