thanks, my repair guy said same thing, but was just looking for others thoughts , Better safe than sorryIMHO … You're good to go.
Check voltage at battery and alternator to confirm gauge reading.thanks, my repair guy said same thing, but was just looking for others thoughts , Better safe than sorry
yes I get it it needs to charge with more than it stands at to replace what it usesThe amperage put out by an alternator is independent to the voltage as far as I'm concerned.
A "12v nominal" alternator usually produces about 14v.
Think about this comparison. Consider the battery as a type of accumulator, it stores energy. If the battery gives 12.6v when fully charged then it stands to reason that in order to drive energy back into the battery in the reverse direction, then more than 12.6v has to be applied to it in order for the process to work - hence my "about 14v" comment above.
Not according to ohms law.The amperage put out by an alternator is independent to the voltage as far as I'm concerned.
If you have a automotive electric rebuilder or a good parts store take your battery and alternator in to be checked. One or both may have a problem.yes I get it it needs to charge with more than it stands at to replace what it uses
but I am NOW at 16.volts at the battery,. is that TOO much
at 14 I was OK with being there, even a little higher, but at 16 volts being put into the battery
the battery is being charged all the while motor is running, so
as at some point when motor is running, battery will be fully charged and then will the 16 volts be Over charging it too much
will it harm things being that high on voltage being run thru things?
well I did have battery checked and it IS good, so, I KNOW I have a good battery in the machine, was load tested by a chain auto parts store, and I have swapped to a different KNOWN good battery tooAll this run around and you still haven't replaced the battery with a known good one?
Have you also tried more than one multimeter to be sure your readings are correct?
