OK managed to get all fuses out and just replaced with all new one's as half of them had turned a whitest color that wouldn;t allow me to check fuse itself, so just scrapped old one's
ONCE I replaced with new one ALL dash lights appeared to be working
I attempted to start machine (battery still at 13.03 volts , checked before trying to start)
machine started RIGHT up, but starter stuck for a few seconds(20-30 seconds ) then kicked off, then while idling, the display, alarm light flashing of and on, then parking brake came on and will NOT go out no matter if brake on or off!
I shut motor off
went and looked in manual for some idea's on things
went to re start machine, and now refuses to start at all
as soon as I put key to power starter TRIES to start machine, spinning slower than normal to me, but spinning starter WITHOUT me turning key to even try to start as in normal starting, it starts to try to start on its own?
parking brake light keeps flashing as does temp light
but will NOT start
I only let it try this 3 times in a 5 minute time period with a slight break in between
then I tested battery with volt meter, and its now reading 12.87 volts sitting!
so battery SHOULD be strong enough to turn faster
a little history on this machine, prior to this, I was having starter sticking issue's, starter would start machine fine, but would stick for a few seconds after starting, not disengaging like after starting!
not knowing how old starter was on machine(but machine used)
I just replaced starter, figured a new one wouldn;t hurt things minus wallet a little!
so new starter a few months ago(maybe 20 hrs on machine since new starter installed)
that didn;t solve issue, then replaced key switch thinking was retaining energy
replaced switch, still had issue
don't use machine much, and NOT the best MR fix it
A buddy that repairs Heavy equipment for a living, offered to come look at things, just never got here before this new issue started
he's been swamped with work and still hasn't gotten here, but says IS coming when he can , so I am looking for help in the mean time
any clue what could be wrong now
new fuses, battery seems to be fine, have NOT tried to swap it with a different battery YET, but did move machine a little when it did start so that can happen! now easier!
why does the starter start to spin as soon as I get power to key?
why does it stick once started, and why is it spinning slower than normal now, ?
any thoughts or suggestion would be appreciated!
I shut motor off
but will NOT start
