operating temp D6C
pkw
california
Ok I checked thermostat: Good
Radiator only has 6 fins per inch. looks to be a 4 core. as Masterlink has stated it should have 9 fins per inch!
Tag on radiator core reads 4n-6296 or it is 4n-629s (hard to read) does any body know if these correlate with cat #?
kshansen
Central New York, USA
Well SIS NPR says a 4N6296 is a gasket and a 4N0629 is a gear in some governor. Never saw a Cat part number with a letter on the end.
4N-6296 is a good Cat Part Number - the only problem is that it's a gasket...….!!
Can you take a photo of the tag and post it..?
Edit: We may have a winner - 4N-6298. Radiator Core used on D6C 10K5205-Up
kshansen
Just looked at the 10K8472 and the radiator core for that is listed as a 4N6298 so for a hard to read tag that might be close enough!
  • D6C Radiator.pdf
By tractor Serial Number it appears as though that Core is the correct one considering the Part Number. That's not to say there aren't other core options available.
The only other thought is that if the core is an aftermarket one simply with a 4N-6298 P/N tag on it for identification purposes of what OEM P/N it replaces then it could be anything …….
Another question to the OP. Have you checked the temperatures of the top and bottom radiator tanks with an infra-red heat gun..?
pkw
california
Here is a pic of tag.
I will check tanks with infrared. tried yesterday but was having technical problems with infrared.....
Master Link
Dallas
Heavy Equipment repair
A little more on cores. Six fins is probably aftermarket even though I did find find one for a 5X D6D machine that had 5.5 fins per inch but it was listed as a trash core. Less fins to let the debris flow through was that theory.
Most aftermarket manufactures used less fins per inch, thinner headers and maybe thinner fins. Copper or steel fins are an option also. A little less here and there lowers the cost. Usually everything works out OK but sometime it doesn't.
Not all aftermarket manufactures are cheap. If you are needing to buy one find out the specs they make there cores to. Of course they'll all say OEM specs so ask them for their dimension.
In the 1980-90s the company I worked for (and still do ) sold 6-800 cores a year, all for Cat. Undercarriage was our main business but we had lots of non-undercarriage parts also. Around 2000 we went strictly undercarriage so I haven't dealt with cores since then, but still remember a lot about them. We purchased all our cores from a company called Dynacore. Dynacore was owned by a parent company called General Thermodynamics. GT was OEM supplier to Cat. I did all the purchasing and dealt with the top person at Dynacore. He told me that there was only one assemble process and all cores were built to the Cat specs. They put the cores going to the OEMs in one crate and market it with Cat numbers and information. They put the aftermarket probably in the same crate, and they were really nice crates, but were marked with the aftermarket part number. I never went to the factory so I can't say if that's true but we never had any problems with them and they were the same specs as OEM.
