operating temp D6C
pkw
california
Hi all, I got a new to me D6c dozer last fall. Ran her all winter clearing brush and pushed in a few roads with no problems. Now that its Summer She is getting hot. I am doing some hard ripping and pushing dozing in a building pad. I was wondering what is the proper operating temp for this machine?
details:
D6c 10k8472
temp reaches 218f +/- and holds dosent boil over as far as i can tell
checked radiator tank temp with infrared- matched gauge reading
new radiator
checked fan blades- in correct pusher position
powershift not getting hot- stays far from the "red" zone on gauge
when warm and put into high idle and neutral she cools down to 190F within a minute or two another minute shes at 185ish
took brush engine guards off- made little to no difference
new belt- checked tension good
3500 elevation
ambient outside temp 100f
Is 218F a okay operating temp or should I be concerned?
218F as a max operating temperature is too high IMO, should be around 200-205 as a max.
The fact that it cools down 20 Deg in less than a minute in neutral and High Idle suggests that the radiator & the rest of the cooling system is working pretty well. The $64k question is where the heat is coming from. What about thermostat(s). Have you checked/replaced..?
No chance that someone has "turned the wick" up a bit..? What does the exhaust smoke look like..?
Another thought. What are you using for coolant..?
pkw
california
Have not checked thermostats. I guess thats where I should start. The dozer was used as a fireline dozer private contractor before I got ahold of her. dosent puff black smoke under load. a little at idle. not sure what that means....
I did manually let the throttle down a bit to see if I was just pushing her to hard, but got the same results. just took longer to get to overheat temp.
as far as coolant I believe its a standard mix of 50/50 glycol. looks the standard green tint I am used to, I was not the one who filled her up last, I just got her last fall.
I did just replace a inoperable torque converter temp gauge. is it possible it is reading wrong? where should I check temp with infrared manually on torque converter to make sure the new gauge aint defunct
belts new
not sure about the crank pulley. how do I check wear ? just look for grooves?
I did tighten belt but made no difference.
Is there only one thermostat on this machine?
The $64k question is actually about $21k Nige, I would have to hunt down a fireline contractor out of ca and beat a thermostat out of him if that was true ; )
DB2
Winnipeg MB Canada
Belts should sit up high in grooves of the pulleys. If they’re below the outer edges they could bottom out and be prone to slipping. Look at the bottom of the “V” and see if it is shiny.
Like this ....... a lot of people don't realize that it's the sides of the pulley that transmit the drive to the belt, not the bottom.
Be careful though - if someone has fitted an aftermarket belt or belts that are not the correct profile you could get the false impression that the pulleys are worn when in actual fact it's the wrong profile of belt causing the problem. Check the belts and see if they have a Cat Part # or aftermarket. Post any data you find, it might help to identify if they are correct or not.
kshansen
Central New York, USA
Have you checked to temperature drop from hose on top of radiator to hose on the bottom? I believe you should be seeing about 15ºF. Nige can you confirm that for me?
Also you say the radiator is new, but have you checked to be sure it is nice and clean and not partially plugged on back side?
One more thing if this has reversible blades on the fan double check that all are facing the same way, had an over heat of a front end loader that was giving us fits years ago only to find one blade was on "suck" and all others were on "blow".
92U 3406
Western Canuckistan
Wrench Bender
Personally I'd start with checking coolant strength as from what I read it was not done. Higher ratio of antifreeze to water has poorer heat transfer ability than 50/50.
I'd shoot the location of the temperature sensor with a heat gun to verify if gauge is reading correctly or not.
Then just the stuff listed above: belts, sheaves, fan condition, airflow thru rads plugged/restricted, thermostats sticking etc.
pkw
california
Thanks for all the suggestions. I will be out at the dozer again in a few days and do some checking.
Master Link
Dallas
Heavy Equipment repair
You might check to see if you have the correct radiator core. You should have one that is 9 fins per inch and 4 rows deep. That's correct for a powershift machine while the standard trans machines only have 3 rows.
Sometimes aftermarket companies that sale cores go on the light side to keep the cost down by doing only 7 fins per inch. The fins are where the cooling takes place so if you have less fins you have reduced cooling.
If it's hot under load and cools down quickly at idle it may be the core is not large enough.
Also check and make sure there isn't any trash in the fins that could be blocking the air flow.
James
DoyleX
Minnesota
I have the same machine and have done all the same with the cooling system. Most of it has to do with the pre cup design of the engine. Puts more heat into the cooling system then a DI. Your gonna have to get out of the throttle more and let it breathe on your returns. When it gets into the 90's I have to start watching it. Biggest thing is to keep the radiator clean. I have found that a leaf blower works great.
56wrench
alberta
did you remove(un bolt) the complete engine side shields? in hot weather you have to remove the complete engine brush guards- not just the removable service doors because the fan will pull hot air from along the engine causing it to run hotter under heavy loads. or, try turning the fan to suction and run it for a while- you'll be down to your underwear after about 5 min :D but the radiator will be pulling ambient air from in front. on old pre-cab machines you either freeze to death or sweat to death except in the spring or fall lol
d or, try turning the fan to suction and run it for a while-
A very good idea, but one that would only work if the engine has a fan with reversible blades. Not all do AFAIK, and some people have the mistaken impression that removing the fan and turning it front to back then reinstalling will change the air flow direction - it won't. all it will do is make the fan push less air in the same direction towards the blade.
56wrench
alberta
Nige, I agree. I never thought to mention that would work only if the fan is the reversible type. all the ones I ran or worked on at the time had the reversible blades. when I was an operator, we would occasionally shut down, turn the blades and run it for about 1/2 hr just to blow the crap out of the fins before shutting down and turning them back
pkw
california
I did not completely unbolt the side covers, Just took the doors off. Ill give that a try when I get back out to the machine. I will also check the radiator core to see if it is the correct one. as well as replace the thermostat for good measure. Ill update the result as soon as i can. The fan is a reversible type. I will also give that a try if all else fails.
I did check the belt pulleys and they seem to be well within spec. The radiator is pretty darn clean. and all fan blades are in correct position. temp gauge was checked with infrared and seems to be correct
Thanks everyone for the input, much appreciated.
kshansen
Old Magnet, do you have the publication number from the book those spec's were copied? I'd like to save them to a folder for future reference!
kshansen
Form #SENR7593-01 Pages 107 & 111
Testing and Adjustments
Service Manual for the D6C Tractor
Why not just copy what I posted?
I did that but just wanted to have the original for any other information it might include. I guess I'm somewhat of a information junkie!
Just saved that SENR7593, puts most of the information for a 3306 in one nice package, thanks!
