Coaldust
- Joined
- May 9, 2011
- Messages
- 3,412
- Location
- North of the 60
- Occupation
- Cargo Tanks, ULSD, RUG, Methanol, LPG
That’s a good point. The DB2 does not like any fuel return restriction.
Thank you for your responce!!! ALL was in time all along. If you read my new post it explains it. Thank you again!!!I’m so lost. I don’t even know who’s on third base and I’m totally sober. We got to get this thing running.
Could that DB2 be 180 out?
Thank you for your response!!! I did check ALL lines and made sure there were no blocks!!! If you read my new post it will explain. Thank you again!!!!i would check the return line and fitting from injector pump to fuel storage tank, may not letting excess fuel flow to go thur, kiss== keep it simple simon
Thank you for you reply!!! I agree with you on the POP. No return blockage or weak pump. The intake system was dismantled and checked for blockage, and there was no restriction at all. And yes, there is compression. I'm not sure as to why i couldn't get a response from the ether, it should have giving me some indication.... Perhaps the battery was to weak at the time, is all i can think of. If you read my new post you will see the results. Thank you again!!!Vetech, this may be the one you've been waiting for, already on page two....On a serious note shouldn't he have at least a pop on the ether, even if he has a return blockage or weak pump? as long as the intake is free of obstruction and can breathe the ether into the cylinders it should at least catch momentarily?? J.W. stated that he got no rhythm at all after go-go juice injection.. Question is can the engine breathe? And is there compression?
Thank you for your reply!! If you read my new post it will explain all... Thank you again!!!!Well, it’s just a standard 3 cylinder, 4 stroke, direct injected, turbo charged?......pretty base set up.
I’m with TPG.....more info and a process timeline is needed.
Thank you for your reply!!! I put a new LIFT pump on her and had the Injection pump rebuilt and set to specs. If you read my new post it will explain. Thank you!!!!I edited your post down to the "pump" part of it.
In your opening post you said that you put a rebuilt injection pump on it. Yes ?
In your last post you are going have the old pump cleaned and re-calibrated.
Are you dealing with two separate pumps ?
If you had the injection pump off are you certain it is now timed correctly ?
