Beetle_Spin
iv got power on 45 key hot on 70 but power on 52 and no wire on 53 on that plug but the plug on the right has a wire in 53 but still no power to it
Or the 10ga cables at the batteries and the weatherpack/deutsch connector in between the batteries and the ECM.Check starter area, make sure all grounds from starter to block to frame are clean and tight.
In some cases depending on application ecm grounds are also attached in those spots.
Sometimes those can be missed when a starter has been changed out in past.
Isn't the electrical system 24v rather than 12v.? Certainly sounds like it when you mention "batteries" rather than "battery". Anything stamped on the starter to indicate voltage.?how much of a voltage drop is normal at the starter i put a volt meter on the power wire and got someone to turn it over we had the batterys on a charger so was reading 13 volts when they turned it over the voltage droped to 8 volts
