Well I have been back into driving it again however it has an intermittent transmission issue. It has always had it but seems to be getting less intermittent.
The symptoms are when the transmission oil is over halfway into the green and I am say in second gear heading down a gradient at half revs, when I finish going forward and go to reverse, put it into reverse, what speed does not matter, it does not make the usual little squeal as the direction clutch engages, instead the transmission when given slight revs makes a noise like the gears are rotating but there is either no movement, or a very weak movement.
Putting it back to neutral and then into gear usually fixes it (changing speeds does nothing), but the hotter the oil the more it happens and then sometimes it will happen going reverse to forward but not as common.
It is nearly like the directional clutch fails to engage properly.
When the oil is cool it changes gear snappily, however it has always been slower engaging reverse then forward by a fraction of a second. Forward direction it nearly clunks in. Reverse when cool oil it takes that fraction longer because you can hear the clutch engage, and the hotter the oil the longer it takes.
There has been no metal or debris on the magnet/filters at all.
