You just had to ask!!!
Well.............Now I'm going to have to tell the whole story.lol
It was the 4th of July 1992. A friend just out the road from me had hired a local contractor to clear a ravine behind his house. The contactor showed up with a Cat 953. The operator made two passes with clearing a few trees and some brush. On the second pass he wasn't able to back up out of the ravine. He went that little extra too far. So,they ended up bringing in their Cat D7 to get him back up out of the ravine. That was it for them. They loaded up both machines and left.
So, my neighbor friend ask if I'd like to clear it for him. I told him I'd do it on July 4th weekend. Anyway I moved my Cat 935C over to his place and started to do the clearing. Once I worked my way down into the bottom of the ravine I put in some old 6 inch waterline to carry the small trickle of water that was there and covered the pipe with about a foot and a half of dirt. Now I had a place to work and shouldn't have to worry about getting stuck because it was wet.
Everthing was going well, other than a couple of Popular tree stumps that he had previously cut off flush with the ground. NO FUN, as I'm sure you know.
Most of the big stumps where done and I still had the clean up to do.
In order to clean up the trees and stumps I had to shove across the hill to make my burn piles. Anyway somehow I ended up below the old waterline I had installed for temporary drainage. The harder I tried to get back up out of the creek the deeper I sank.
Luckily I still had my old Cat 941B that was up for sale. I called a good friend of mine that has a small excavating company and explained the situation to him and he said he would go over to my place and move the old 941 over and we could use it to pull out the 935. Well we tried everything. We were afraid to take the 941 down into the ravine,because we figured both machines would end up being stuck. He had enough chain to reach the 935,but the 941 just could not get enough traction to pull out the 935. We tried and tried. It just wouldn't budge. By now its starting to get dark and the 935 is so buried that 2 more inches and there will be water running into the fuel tank. Plus it was calling for rain later that night. Sh**! What am I going to do? OK, I said lets try this. So I hooked up a chain on each side onto the shoe pad at the bottom as close to the ground as possible. The 3/8ths grab hooks just fit. Now I took out all the slack from the chains running from the 941 to the 935. Got back on the 935, put it in forward gear and slowly gave it some throttle. LO and BEHOLD! It walked right out on those chains as the track moved rearward it pulled just like a winch. The only thing I said was. "We should have tried that 8 hours ago! Geez, what an ordeal. I think I spent more time dropping the belly pan and cleaning the machine up than I was on the job. Needless to say I didn't make anything on that one,but I did learn a great way to get unstuck. I've used this method more times than I would like to recall to get myself unstuck. Most of those times I was able to tie off on a tree at the base and only use a chain on one track to get out. It works,but its still not easy work. Sorry to be sooooooooo long winded,but it raining here today, so I thought it would be a good time to tell a story and maybe teach someone else a method of getting up stuck when you are by yourself and there are no other machines to pull you out.
Sincerely,Dirt
