New to this forum.
I have acquired a MF 50 (i think) Industrial loader/backhoe. I want to find out if in fact it is a MF 50 (or A or B, etc...) so I can purchase the right manuals for it. Searched the web and photos of a MF 50 Industrials do not seem to match up with mine.
Here is what I know:
- Partial Serial number on the inside plate says: 9A???52984. Searched the web with no luck on the last digits. Even emailed AGCO (new MF company) with no reply.
- Loader is an MF-300 serial # 1196-00 4437
- Backhoe is probably a MF 54 not the narrow 54S
- Perkins diesel engine AD4.203
- Instant revese transmission (4 forward and 4 reverse) using a dual pedal design
- attached some photos (max 5 allowed)
The engines starts and works. Some smoke but seems to work fine no abnormal vibration. Hydraulics working, but maybe not as strong as it should be. Never reved it up to max. Gauges not functioning. Fuel leaks from injector connections.
As well a leak occurs at the bottom of the engine transmission section (see photo 5180) that starts after 15 minutes, black engine oil not trans oil, from the metal gasket area. Tightened the four bolts underneath but still leaks.
Any assistance would be appreciated. It is used for a non-profit organization for a youth camp. Purchased in early 1980.
Thanks,
Dan
Thanks,
Dan
