Memories for us old truckers
4x4ford
Las Vegas Nevada
aunts on the strip Currently drive a 1951 chevy pa
Saw a yard dog do that test with a load of brand new engines at the gm plant in wentzville 2yrs ago caused a full shut down as he blocked about half of their receiving doors
BCIV 400 CPL 676 converted to full flow cooling. Lower press fit liners with double nie pistons, std mains
& std rods, new cam bushings. Inspected cam and followers & reused. Rebuilt accessory drive, compressor,
pump and injectors, heads were almost new condition but were disassembled and completely checked over,
replaced four exhaust valves and all hand lapped. Jakes disassembled cleaned inspected replaced any worn
parts. Oil pump disassembled, checked met standards reused. Oil cooler disassembled inspected resealed.
New water pump and new single entry HT3B turbo. Block crankshaft housing bores and rods checked for
out of round, crank checked for out of round all {OK}. All seals and gaskets replaced. Test run {runs good}
FOR SALE----------------if anyone is interested-install your BC I,II or III aftercooler and your flywheel.
Pump set 10% over in fuel and fuel feed in from both ends, approximately 430 to 435 hp.
Birken Vogt
Charter Member
Grass Valley, Ca
I thought hand lapping was out of fashion on anything after 1950 because the expansion of materials would cause the contact patch to be in a different spot than when it was lapped cold?
Did you make your own tag there? Try to help the next guy know what is inside it?
That hand lap idea is a fallacy. Lapping is done to remove any imperfections from seat and valve face.
The valve stem clearance allows some movement on the seat anyway.
You can't and haven't been able to buy blank engine data plates from Cummins for quite a while. They have
to dyno certify the engine and stamp the tag.
So yes I made a data plate to show what it is and crank/block info.
Cheap "old" Geezer
I did not make a engine data tag for the Cat yet have all the parts used information, Block S/N, Processor Engine Conversion to S/N so when a Tech plugs in it is the one listed not the OE engine but hard parts all fall back to the OE series. Mine is a Frankenmotor now.
crane operator
sw missouri
This ones not that old, but its sure up there in price. Its a 1998, KW. Big cat and 18speed. Double steering boxes up front, and spring over walking beam with a tag axle. Its up for auction, and its right now at $71,000. It doesn't sell until the 17th of feb.
Better hurry up and get yours finished DMiller- the market is hot right now.
https://www.purplewave.com/auction/...-Kenworth-W900-Trucks-Truck_Tractor-Minnesota
1998 kenworth heavy 1.jpg 1998 kenworth heavy 2.jpg 1998 kenworth heavy 3.jpg 1998 kenworth heavy 4.jpg
Cheap "old" Geezer
I still like Simple, basic needs and function. Rubber Floor Mat is convenience to me instead of carpet, nice paint, shines where should components. Time spent dressing one out to a extreme is a waste as does not haul better or necessarily impress anyone but one's self. I do like a FEW accoutrements, just not dangles and bangles everywhere.
