Columbo
I’m working on a few undercarriage repairs on the excavator and I may need to split the track to remove the idler. This machine has aftermarket DCF rails (p/n DCF 1-0324 is cast into the links). I could not find any typical master pin arrangement when I examined the pins. One of the pins is slightly shorter and with rounded ends, I think this is the master and it looks like it is a friction fit without other retention? Can anyone with experience with DCF undercarriage confirm that this is the master pin style they used before I go medieval on it with a sledgehammer? Pics of both sides of the pin and one showing a neighboring pin for reference are below. Thank you!
Outer:
Innner:
Outer:
Innner:
