Dr. Ernie
No, you are not nuts... water doesn't lie and keeps you honest.
I use a Liaca depth master reciever and while it works well the water is the ultimate grade checker. Try rolling your bucket into the full dump position and using it that way to check the grade. I pull it to grade by eye then I will come back and check the grade after the last pass. If the previous pass was on grade it should be easy to tell if you are spot on. I f conditions are right I generally check the grade every other pass, sometimes I may go 50' between checks or more it just depends on how good I am that day...
I am just bloody good. .
