Simon C
- Joined
- Jul 1, 2015
- Messages
- 679
- Location
- Rocky Mountain House , AB., Canada
- Occupation
- Heavy Equipment Mechanic
As " Simonsrplant " said, there is no substitute for big equipment if working on big dollar equipment. How much customers want to pay depends on big production job or getting it fixed in next month or 2. If your going to torch out always good if it is a centre greased pin to blow out the grease into a rag, put a wire with 1/8 inch 90 degree bend on end into grease bore to find out which direction the grease cross drilled hole is. You want to start the burn 1/4 inch or so away from where that direction is and come back to that cross drilled passage when 80 percent around on burning. Before you start burning you can try to wash out any additional grease from bore and blow out thoroughly, but make sure whatever you use to wash out the grease is not laying close by as it will ignite once the sparks start flying. Not even a bad idea to have clean coveralls on that dont have any flammable residue, or you will go up in flames.
In the end what works for each situation will be different. WTC makes a sledge hammer setup for knocking out pins that will work and some have made their own.
A little heat and 12 LBS of hitting has taken many out.
Simon C
Simon C
