Ratmotorhead
Thanks guys for the quick responses. I do have a valve under my right footrest that does not have a pedal on it ,along with both left and right track controls. I will see if it is functioning properly and not stuck.i assume that could be a partial open in the circuit, and not allowing my pressure to reach the correct values. I am not one to know my hydraulic symbols as good as some,thank you. Another question I have is that I do not have a way to control my mode switch, there is a solenoid on the regulator block that when I supply voltage it bleeds off pressure back to tank . I leave it disconnected when in use ,but I could use more info on its use to the regulator. I am understanding that when the engine is at full throttle the regulators are mechanically operating? I will try stalling the tracks and see what happens . I will work on it again this weekend thanks guys
