Ratmotorhead
Hello gentlemen. I believe I've made some headway on my excavator. Upon pressure testing I have found that I had no unloader pressure (which would be my set pressure.) I believe that is why it would not let my swing brake release. This set pressure from my unloader valve had a line going directly to my left and right swing spool which may be giving me my non brake release problem.
I also disconnected the free swing valve and plate underneath the brake by plugging them. Has John C. ever disconnected the free swing feature on a 4300C Link Belt? Any comments from those of you with more experience than me?
In the past I have had good pilot pressure and relief pressure at the swing brake. 3900 pounds on left and right swing. But no set pressure since the unloader valve was not working. A rebuilt unloader valve now gives me 3900 PSI pressure to send back into the spool. Does that pressure operate my crossover relief valve? This could be the culprit.
