1. My 1994 PC75UU-2, Serial number 8310, Engine Model # 4D95L-1, was getting harder to start. I replaced the batteries but still turned over slow. Had a friend try and start while I watched and fire/smoke came out of the rear of the starter motor. Now it won't turn over at all. I suspect the armature is dragging on the field coils. I need to remove the starter and don't have the service manual.
Do I have to take the counterweight off to access the starter, or can I remove enough linkage and manifold parts to get it out through the top?
2. Update: I hooked two batteries up in series and applied 24v. to the starter solenoid and then to the starter motor and then the solenoid after tapping on the starter housing. The solenoid engaged normally, but the starter motor contact arced a little but didn't move. After several tries, I guess I jolted something loose, because it started, turning over at normal speed. It remains to be seen whether it will start tomorrow, but there is clearly a problem. I was desperate to get it started because I wanted to get it somewhere I could work on it and put it in the right orientation.
3. Finally, the oil level is increasing. I can only imagine that somehow diesel is getting into the crankcase and mixing with the oil. Maybe the diaphragm in the fuel lift pump, as has been suggested elsewhere. So...where is the fuel lift pump?
4. I have a parts manual in Japanese and and operation and maintenance manual. Anyone have a service manual?
