My 1994 PC75UU-2, Serial number 8310, Engine Model # 4D95L-1, was belching black smoke and spilling fuel into the crankcase. Air filter was clean. Started well, ran well, but smoked under even a light load. Injectors were just rebuilt. Decided it was the Injection Pump. Took it off, sent it away and had it rebuilt and the shop said it was bad. Got the rebuilt pump back and installed it. Tried to time it like the book said.....Take out the spring from the valve holder and hand pump while moving the pump away from and toward the engine block. It's supposed to be timed when the flow stops. The flow never stopped. Turn engine over and try again....still no flow stoppage.
Finally, I put it all together and set the pump where it had been before and tried the starter. It started, but still isn't timed. Is there a way to dynamically time it with a timing light? The marks on the crank pulley line up with the timing pointer and, though they're hard to read, look like 8 before, a series of gradations, 4 before, and then a space and a single mark. I tried the timing on the single mark.
What am I doing wrong? Probably plenty, but I would be grateful for advice. Thanks.
