Rob Gunn
Komatsu PC40-6 excavator SN:13942 with 3 cylinder diesel engine model 3D95S-W-1 SN:21475
For some reason the plastic radiator cooling fan exploded. I contacted the “MYKOMATSUPARTS” and was told that the replacement fan would be #600-625-0410. That also matched what I was able to find via Komatsu parts book v5.0 on line.
I ordered it last week and received it today.
Now that I open the box I see a difference in old vs new. The old fan was the same outer diameter as the new one (approximately 16”). The hole mounting for the water pump appears to be the same. However the old fan was 6 blade and the new fan is 8 blade.
And the biggest difference is the opposite air flow due to the blades. The old fan would blow from engine compartment toward the radiator and out. The new fan would suck from outside thru the radiator and into the engine compartment.
Im not real confident in the parts guy and what I was told…
I do understand that sometimes manufacturers will make hidden changes that may be a improvement but this just seems odd to me. Any input from any experts?
