Working on a friends machine and not quite sure how bad it’s looking. Started with a no start/no cab power situation. I found no power at the key so I ran a jumper wire from the batteries around to the key, everything in the cab now works and the machine starts with the key. I’m assuming broken/chewed wire. Second issue is an issue with faulty shutoff solenoid. Have to hold it open manually to get the engine to run. I tested for power with the key on at the 3 pin connector for shutoff, no power on any pin. I tested for ground and have a ground on all three pins. Should I automatically assume broken wires or could it be a fuse/diode? If so where and how do I test the diodes? Third issue being throttle. Machine had no throttle so they ran it with throttle pulled manually. Tested for power at plug for throttle knob, had 5 Volts on one. Tested resistance on knob and had OHM reading from .6-4.4OHM as we turned the knob. When trying to use the throttle with machine running it won’t go above idle and the stepper motor or actuator makes a high pitched noise until the key is off. When the key is on you can’t really move the motor manually but when the key is off it moves freely. Any help is appreciated. Thank you.
