Connstellation
Hello
I have a komatsu pc220-3 excavator sn 22737. This machine has a lot of backstory and work into it but to make it quick and simple, I rebuilt the motor the machine ran great for 30 hours or so. During a run my operator said he felt the main boom lift was suddenly weak and 10 minutes later there was no boom lift. Machine got parked. Said operator got in it and forced the boom free which released a loud bang sound supposedly.
Upon main boom cylinder disassembly I found the bore nut to be severely loose and the bore to have exploded beyond repair due to movement. So I rebuilt the other cylinder and bought a factory original for actually really darn cheap. So two new cylinder rebuilds are on the machine now. Contamination seems to be pretty small and I have probably 99% of the pieces.
On first run the boom up is stuck open. I can open the joystick for boom up more, but I get no hydraulic whine for down. I checked lines for the pilot system from the joystick to the spool and it's all clear. So I took apart the spool on both sides and tried to pull the spool, I had to hammer it out. It was tight, took a lot to hammer it out. So at this point I'm assuming my operators loud boom was something in the valve body related to that spool. So I figured out where the tight spots were and made dowel rod sand sticks with 800 grit sandpaper. You may not agree with this way to attack it, but I had very good luck with it, or so I think so far. After a lot of trial and error I got the spool very smooth. Im still within .002 inch tolerance though, from what I can measure I did not take away much material.
So when back together I have no bypass that I can measure and normal use of the spool up and down, until I go to lift the boom maybe 90% of the way up, same problem as before. So I open the valve body again thinking I'd be tight again but I am as smooth as I can be after i relief pressure.
But, I did notice the spool is stuck up, about 1/4 inch out of neutral position. With fluid force acting against me [I push roughly 60 pounds of force with my thumb guesstimate] I can't push the spool to neutral but I can pull the spool out towards up more, relieve pressure, then push the spool to neutral.
I tested the beehive springs that act on spool to neutral, they're both close, 240 pounds at 1.5 inches suppression, 450 at max compression. I assume at 1/4 compression theres not 60 pounds of force. But I would consider these springs like new at these pressures.
So I'm wondering if the spool isn't somehow catching something from a raised edge, fluid pressure is preventing the spring to return spool to neutral, or?
My next plan of attack is to start machine after it sat and see if the spool is free after pressure relief. I plan to pull spool again and check for straightness with a more accurate method. I plan to check the valve body lips with a pick and check for an edge that may raise while pressurized. I plan to polish the spool [the only noticeable "marking" is normal wear on the very ends but no scoring]. I can't justify taking anything more away from valve body because it is so clean now.
Again, when pressurized I can't return spool to neutral by hand, but I can pull spool out towards up which relieves pressure, THEN I can push to neutral freely. Upon reassembly I have normal operation until I raise boom to 90% then my spool sticks to boom up, and then my pilot system still engages and disengages properly, but the boom lift is stuck open a 1/4". I was able to return it to neutral with pilot system only once.
Rest of machine operates correctly and normally. Machine worked properly prior to cylinder blowing up. I was able to lift boom all the way up and down a couple times between disassembly, so it doesn't always get "stuck". I recovered 99% of debris.
What am I missing?
What am I missing?
