Hi,
What I know is when single travel lever is operated forward or reverse only one oil pressure switch/sensor located on the merge-divide valve of the control valve designated for that particular side of pump should display pressure on the screen. Why is that when I operate the right travel lever the screen displays pressure on both 011 & 012, but when the left travel lever is operated only 011 entry on the screen displays pressure approximately 375 bars while the 012 entry shows only 40 bars, which I guess is normal.
Does this mean that both pumps work on the right track? Is this something to worry about?
Thanks
Thanks
