Larsgranstrom
Hello guys, I have a pc210-6 it has a throttle control problem . It won’t rev up at all from the control In the cab. I can manually move the linkage on the control motor and it will rev up but goes back down on its own. Also turning the key off does not shut it off. It shows code e05. I started poking around at the wires out of the throttle control motor and noticed a red wire worn all the way through, I fixed that and the problem still persists. Sometimes when I turn the keyboard on the throttle control motor makes noise and tries moving back and forth .
There is a switch under the fuses in the cab that says TVC . I have switched it back and forth and it doesn’t seam to change anything. I have checked the fuses .
Any help is greatly appreciated.
Thanks !
Lars
Thanks !
Lars
