papa_twebb
My 200 will over heat when working . I can stop using hydraulics for a few minutes and it cools down. radiator and hydro cooler is clean enough to see thru. It seams as if hydro fluid is too hot. IT takes about 2 hrs for it to get to hot range. Replaced hydro element, old one looked ok. there is also a strainer in hydro tank, could it also restrict flow. Does not over heat when doing light work but will when digging. baffles are ok around rad.The 1/8 plug is out in housing between engine and pump. Water in rad stays full. I have not checked thermostat. Would removing therm help. Hydro fluid tank is full. Air filter is clean. Fan blade has small notches in end of blades where it had set on shroud before replacing engine mounts. What could it be, what am I overlooking.
Thanks for any help!!!
