I have a PC200-6 that will spin over but no start. If you aid a start aid it starts right up and will run all day. As soon as you turn it off, it will not start back up. Whether it's been 10 seconds or 2 hours. Has anyone seen this issue before?
Thanks guys. Unit is getting good fuel, has low compressionCHECK the things John C. mentioned.. especially the solenoid travel..
IF all that checks out, I'll bet that the pumping plungers are worn & not allowing enough fuel at start-up.??
Theres away around it..depending on WHICH pump you have..
You can post a pic here of the inj. pump or send it to my home email {probably easiest}.. just put at a o l dot com after my screen name in you home mail service. A pic of the side & especially the front of the pump.
