John C.
You are correct about the computer modulation. You can check the solenoid by removing it and checking the plugger. Turn the key on and hold your finger over the plunger on the end of the solenoid. You should feel it move in and out as you shift the mode switch on the monitor panel. The other thing you can do is reinstall the solenoid and disconnect the harness connector and then operate the machine. The pump should be able to overload the engine in that case. You can check the pressure coming out of the solenoid as well. You can also check TVC pressure. If you look at the center of the pump and in between the two control blocks on the pump, you will see an eleven sixteenths bolt head. That is the passage for checking the TVC pressure. With the engine at high idle, mode in HO and power in H and the controls in neutral, the pressure should be somewhere around 360 PSI. With two pumps running with a control dead headed over relief, you should see somewhere around 270 PSI.
