Komatsu pc128 won’t start
Jjkg1990
Hawaii
My Komatsu won’t turn over. When I turn the key one everything come on. The only way it will turn over is if I connect a ground wire to the alternator and ground it to the machine. After it starts I can pull the ground wire and the machine will run fine. Changed the safety starter relay. New alternator also. Power going to the alternator. Any help would be helpful. Thanks
There are Dash numbers on the end of the model number that we need. The case of the alternator is supposed to be grounded all the time anyway. Unless the engine or machine won't shutdown, why not just put a permanent wire on and be done with it.
heymccall
Western Pennsylvania
I'd search for a broken ground strap from the lower engine block to the main frame.
I believe I circled it. Bellhousing (counterweight side) to frame below. Screenshot_20200715-141615_Chrome.jpg
