125IIIA
Hey Guys,
I have a Komatsu PC120-2 SN 16129 It's a late 1984 or early 1985. The right side track motor has been getting slower and slower since I purchased this unit about a year ago. When the hydraulic oil is cold it isn't to bad but as the oil heats up it gets a lot worse. It is just as bad if not worse in reverse. I pulled the return line off the travel motor and ran it at full throttle for one minute with hot oil and the track stalled and got 23 ounces from the right and only 4 ounces from the left side with the same test. I believe it's the pistons, shoes and cylinder inside the pump that are worn. I have the shop manual but there are no specs for such a test. I preformed the leak test in the book and the motor passed. That test is basiclly the same but you let the track rotate freely in the air for one minute. Does anyone have something else I should look at before I order a $3000.00 used final? There are no parts or rebuilt finals for this machine out there that I can find. The motor is a Teijin Seikco GM15G-A-78 The excavator has 6000 hours on it and I have rebuilt the swivel joint and did a few other checks before finding the leakage in the travel motor. Thanks for the help,
Matt
Matt
