Kobelco SK75SR hydraulics randomly stop.
Tags
Connecticut
Serial # YT08-30095. Been running this machine and the hydraulics will randomly stop. No functions at all, then will all of a sudden come back. If you lift the safety lever and then lower it, it beeps, signaling it has been engaged but it won’t activate the hydraulics, if it sits for a minute they come back. Thinking it may be a lazy solenoid?….just waiting for it not to come back though. Any help is appreciated.
Kobelco ireland
Ireland
Mechanic
Hi if it beeps the switch in arm rest is working. Like you said lazy solenoid is most likely problem. You could swap it with the two speed track solenoid to get you going
uffex
Lincoln UK
Admin
Good day
Such issue soften originate from loss of pilot pressure, root cause can be pilot pump or relief valve in addition to electrical issues as pointed out. A sensible method of diagnostics would be to install a low-pressure monitor to the pilot line.
Kind regards
Uffex
  • Like
Reactions: DB2
Tags
Connecticut
Thank you both. Machine only has 3000-ish hours and has been well looked after. Would like to try swapping the solenoids first, if it persists we go into pressure testing.
Kobelco Ireland, any chance those solenoids are numbered?
Tags
Connecticut
Thanks so much for taking the time to supply that info, I really appreciate it! Was just looking at it this morning when you replied, that’s a massive amount of help.
