Well yesterday was one of those days you don't need too many of. I went and off loaded a cell tower in the morning, and it went fine. The tower guys were a bunch of skeptics on whether the 25 would unload it. I don't know what they usually get sent out for a crane to offload (the biggest section was only 10,000lbs), but evidently its a bigger crane than what I sent. If I had a 150 ton crane, I could have set the tower, but I'm still saving pennies for that.
It was after the cell tower that things got worse. I took the 70 ton down to the big condo forever project to put up some more sheetrock, trim, and vanities, bathtubs etc. At the steepest part of the hill, I felt something let go out back. I think the crane slipped a little with the weight all up on the steers, then grabbed (jakes on) and popped a axle.
I put the power divider in, after checking to make sure it wasn't a driveshaft/ ujoint, and climbed up into the jobsite. I think I may just leave the axle alone, and drive it back to the shop like it is. If its broke and just a stub sticking out of the 3rd member, I'll have a hard time getting it out on the jobsite. Its only about 2 miles back to my shop, I'm thinking of just limping it home and fixing it there. I'm afraid if I take out the outer broken half, the inner piece may fall down and hang up on the 3rd member, so maybe leaving it all together might be a better choice.
When I got to the jobsite, one of the other guys sent me a picture of the tire on the RT. It had developed a baseball sized lump on the side of it. After he got done setting steel, it popped driving out of the way, but the tire itself still has air. The outer layer just separated from the belts, and it split there, the tire is still up. New tire is supposed to be in late today or tomorrow. They don't give away 23.5r25's either.
